Still undergoing attempt to boot Umon from SD
Ed Sutter ed.sutter at alcatel-lucent.com
Mon Jun 29 12:33:58 UTC 2015
Jarielle/Chris,
I have changes made to eliminate the use of libc.
This weekend I had "some" success pushing code back to the master.
I managed to get Jarielle's patches pushed in, but then I tried to push
a few updates for the libc stuff (ctype.h) and also an updated makefile
to use the RTEMS tools.
Hopefully this will be resolved by tonight, and the master can be cloned
and immediately followed by a successful build of the beagleboneblack port
using RTEMS tools and no libc.
Ed
> On 29/06/2015 12:10 pm, Jarielle Catbagan wrote:
>> I did worked on trying to get "raw" mode working very briefly before I
>> switched over to try to boot off of an MBR/FAT filesystem.  I actually
>> did not take into account about the potential issue with SFN/LFN, but
>> now that you mentioned it I'll try to get "raw" mode working.
> I suspect the reason umon is not booting is common to both approaches.
>> Interesting, I'll definitely take a look into it to see if I could use this.
> The #beagle IRC channel maybe able to help.
>> I did manage to get Umon built using the RTEMS tools.  One thing worth
>> mentioning is that the current Umon sources has an external dependence
>> on the C library, and so I had to link it with the RTEMS C library.
>> The reason for this external dependence is that the previous Umon
>> version contained files that defined functions that would otherwise be
>> defined by the C library but had to be removed due to a conflict in
>> licenses.  In the meantime until a solution is provided to remove this
>> dependence on the external C library, Ed has provided me with the
>> necessary files as a temporary fix for now.  With these temporary
>> files, I am able to build the current version of Umon that I have
>> right now with the RTEMS tools without linking to the RTEMS C library.
> Not using RTEMS's libc is important.
> Once the files are in the umon repo I will build and take a close look
> with JTAG.
> Chris
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
