RTEMS with post-boot code.
Joel Sherrill joel at oarcorp.com
Wed Oct 29 16:09:25 UTC 1997
On Wed, 29 Oct 1997, Patrick F. Harris wrote:
> On My home brew system. I use a scheme that forces the host linker to leave
> a hole in the memory map for the module under test. I then have the linker
> link the debug object into the hole, and do an absolute down load into the
> reserved space.
This sounds like the trick with gld that I was referring to.
--joel
Joel Sherrill                    Director of Research & Development
   Support Available             (205) 722-9985
