RTEMS with post-boot code.
Erik Ivanenko erik.ivanenko at utoronto.ca
Wed Oct 29 21:58:21 UTC 1997
Jacob W Janovetz wrote:
> >       The compilation manager changes the linker script to use the address of
> > this region as the start of the program sections. ( Recall we have put
> > them in order, prog-text, prog-data and prog-bss. )  We then recompile
> > and relink.  Afterwards, we extract only that program section from the
> > resulting image. ( eg. about 112 bytes for hello world ).  we send this
> > image down to the program manager, to be loaded into the given region. (
> > again via UDP )
>   This seems unacceptable to me.  Depending on what is wanted for
> any given situation, I agree that trade-offs must be taken.  I
> would much prefer to less segmentation than to have to recompile
> and relink for every download.  On each "host" connected to my
> "target", I want a bunch of applications.  I accept the need for
> a download manager (on the host) and a program manager (on the
> target), but I don't accept the need for cross-compilation and
> linking tools on the host.
>    At this point, I like Joel's recommendation of the linker option,
> but I didn't know that existed.  I have to look into that.
>    These are all great options!
>     Cheers,
>     Jake
I think what I've actually done is worked around not knowing about the
link with addresses only option.  The result should be the same:
	A stripped down image that contains only the thread, located at some
address.
What you still have to do is to locate that thread. The problem is
compounded when
one considers that threads can be deleted.  How do you reclaim the space
by using
ONLY "link with addresses only"?
Erik Ivanenko,
Supervisor, Controls Services
University of Toronto
