RTEMS with post-boot code.
Jacob W Janovetz
janovetz at ews.uiuc.edu
Wed Oct 29 21:21:40 UTC 1997
> The compilation manager changes the linker script to use the address of
> this region as the start of the program sections. ( Recall we have put
> them in order, prog-text, prog-data and prog-bss. ) We then recompile
> and relink. Afterwards, we extract only that program section from the
> resulting image. ( eg. about 112 bytes for hello world ). we send this
> image down to the program manager, to be loaded into the given region. (
> again via UDP )
This seems unacceptable to me. Depending on what is wanted for
any given situation, I agree that trade-offs must be taken. I
would much prefer to less segmentation than to have to recompile
and relink for every download. On each "host" connected to my
"target", I want a bunch of applications. I accept the need for
a download manager (on the host) and a program manager (on the
target), but I don't accept the need for cross-compilation and
linking tools on the host.
At this point, I like Joel's recommendation of the linker option,
but I didn't know that existed. I have to look into that.
These are all great options!
Cheers,
Jake
janovetz at uiuc.edu | Once you have flown, you will walk the earth with
University of Illinois | your eyes turned skyward, for there you have been,
| there you long to return. -- da Vinci
PP-ASEL | http://www.cen.uiuc.edu/~janovetz/index.html
