RTEMS with post-boot code.
Jacob W Janovetz
janovetz at ews.uiuc.edu
Wed Oct 29 21:45:57 UTC 1997
> Jake,
> going by what has been written so far - it really looks like what you want
> is RTEMS to be able to execute an image it gets from <insert-your-favorite-
> storage-place-here>. When the application is done, it's done. Another
> one could be run afterwards - or maybe at the same time.
> It sounds like you really are looking for a "real" OS - one that can dynamically
> load images (programs, executables, whatever-you-want-to-call-it) and
> run them. All without rebooting/reloading/restarting/resetting. Like I said,
> a "real" OS. For this, correct me if I'm wrong (I'm sure you will), but wouldn't
> you need an MMU and code to run it? Not to mention the CPU to go with
> it.
That certainly seems more along the lines of what I'll be
trying out. However, is an MMU really required? I mean, assuming
memory protection is out the window.
I'm really quite new to the RTOS/C code on embedded systems thing.
Cheers,
Jake
janovetz at uiuc.edu | Once you have flown, you will walk the earth with
University of Illinois | your eyes turned skyward, for there you have been,
| there you long to return. -- da Vinci
PP-ASEL | http://www.cen.uiuc.edu/~janovetz/index.html
