compiling egcs for rtems under cygwin32
Mike Davies mikert at noco.demon.co.uk
Wed Apr 22 17:59:48 UTC 1998
In message <19980422072222.11383.rocketmail at send1d.yahoomail.com>,
Geoffroy Montel <g_montel at yahoo.com> writes
>Hi!
...snip...
>Gloops! Which version of binutils are you using?
>I didn't try binutils-2.9 yet but I was told it doesn't compile well
>under NT.
Im using Binutils-2.8.1
>I have to check this.
>Maybe you could try binutils-2.8.1.0.18, it's on my ftp server:
>ftp://192.33.150.29/out/
 ...snip...
>??????????????????? Your files are empty, aren't they??
>Have you got a problem with your clock? They were all created on Jan 1
>1970!
>Make must be upside down!
I think I've forgotten to set my clock !
>You have a problem with binutils, it didn't compile successfully.
>You should try the build procedure one more time from scratch, and store
>every configure and make trace on files.
>For ex:
>binutils/configure [blah-blah] >trace_conf_binutils
>2>trace_conf_binutils_err
OK I'll have a go
>Does anyone know on the list if things for PPC has been changed since
>2.8.1 ?
>(PPC is your target processor, isn't it?)
No, I'm using the i386.
>Courage!
OK :-)
>Geoffroy
Thanks a lot,
Mike
