libio preparation for file systems
Eric Norum eric at skatter.USask.Ca
Tue Feb 24 15:11:08 UTC 1998
Brian Cuthie <brian at systemix.com> wrote:
> I agree. If I want UNIX on my embedded board, then I'll run it.
> Even now in RTEMS it seems kind of silly that there's a name,
> "/dev/console" for the console device. A constant identifier,
> compiled into the application from a header file, would do just
> fine.
I think "/dev/console" is good.  After 20-odd years of poking around
operating system code I am confident that a uniform namespace is the
way to go.  It doesn't have to be that expensive in speed or space,
either.  The present libio scheme is almost good enough (cf. the
/TFTP/host/filename driver for TFTP file transfers) but has some
rough edges and a few missing entries (no stat() entry).
On major argument in favour of a common namespace is that it lets us
leverage existing C stdio library code and other existing source.
> The only reason devices are named in UNIX is because programs are
> loaded onto machines whos configurations may have changed since
> they were compiled. Therefore, it's necessary to abstract the
> platform from the application through the API. RTEMS doesn't have
> this problem since everything is built for the target and linked
> into the RTEMS image.
But a common namespace makes it easier to use driver code from other
systems, lessens the learning curve for new programmers, and makes
it easier to use existing library code.
> I applaud the efforts of Joel and OAR. But, rather than try to
> build the wrong "me too" features into RTEMS, let's keep it the
> great RTOS it is by keeping it an RTOS.
Actually, it's a `real-time *executive*' now.  Adding filesystem
support (and perhaps memory protection) would bring it into the range
of a real-time operating system.
> Now, Joel, if you have some time on your hands... A really nice
> featre in RTEMS would be process memory protection. Much more
> useful in an embedded OS than device names, IMHO.
I can happily live without the hassles (and often the overhead) of
memory protection in the applications I'm working on.   I'm against
anything that adds to the context switch time :-)  Actually, I expect
that some kind of memory management is going to be required for more
modern processors that need it to be able to use cache.  Once that's
required I don't see much more effort to make protection work, too.
Eric Norum                                 eric at skatter.usask.ca
Saskatchewan Accelerator Laboratory        Phone: (306) 966-6308
University of Saskatchewan                 FAX:   (306) 966-6058
Saskatoon, Canada.
