libio preparation for file systems
Chris Johns cjohns at plessey.com.au
Wed Feb 25 23:47:41 UTC 1998
Joel Sherrill wrote:
> On Thu, 26 Feb 1998, Robin Kirkham wrote:
> > On Tue, 24 Feb 1998, Joel Sherrill wrote:
> > It's occurred to me that if we have an effective system of mountable
> > namespaces, which are easy to implement, you can have the best of both worlds.
> > You would write your ADC driver (or whatever) not as a driver, but as one
> > of these namespace/filesystems. This particular space would implement
> > a flat namespace consisting only of numbers, one for each channel. This
> > you would mount on, say, /dev/adc, so that the ADCs were /dev/adc/0,
> > /dev/adc/1, and so on.
> Cool idea.  This would be a very good way to do the discretes.  You could
> even have the names as word-start-width-return_type.  So 0-3-15-32 would
> read work 0, starting at bit 3, for a width of 15, and return it in
> an unsigned32.  Having mountable file systems of varying types is a very
> powerful thing.
I also agree. I have been looking for a way to manage a very basic
element management user interface. I decided a sort of directory tree
would be the way. For example the rtems monitor. If a basic shell
existed, a user could enter
$ cd /cmds/mon
$ ls
< list of monitor commands >
$ task
< monitor task command output >
The sort of approach above would help to achive this. All this
filesystem would do is call functions with the remainder of the
command line.
Regards
 Chris Johns  Networks, Plessey Asia Pacfic Pty. Ltd.
  mailto:ccj at acm.org    mailto:cjohns at plessey.com.au
