4.0 Beta PC version problems
Brian Stevens
bstevens at dra.hmg.gb
Tue Jul 21 08:01:26 UTC 1998
Hello,
I have built the i386-pc version of rtems and produced a bootable
image using grub. However, the bootdisc will not work on one type of
PC (Dell Optiplex 466/MX) but seems to work ok on the other types I
have tried it on.
The steps are as follows :-
1) Boot machine
2) Loads GRUB
3) Select Hello world test from grub memu
4) Kernel = (fd0)/hello.exe message
5) Loading message appears - Loading: [format=NetBSD-a.out,
loadaddr=0x100000, text=0x16d60, C, data=0xde4, bss=0x3c74,
entry=0x100000]
6) system hangs.
Unfortunately the spare PCs that I have available
for use with RTEMS are Optiplex 466/MX
Does any one have any suggestions.
Thank You
Brian Stevens (bstevens at dera.gov.uk)
Tel. +44 1252 393959
Fax. +44 1252 395120
Sensor and Avionic Systems
Defence Evaluation and Research Agency
The information contained in this E-Mail and any
subsequent correspondence is confidential and is
intended soley for the intended recipent, any
disclosure, copying, distribution, or any action
taken or ommited to be taken in reliance on such
information is prohibited and may be unlawful.
