Installation woes
erik.ivanenko erik.ivanenko at utoronto.ca
Thu Mar 5 23:59:08 UTC 1998
I have been trying to follow the INSTRUCTIONS.  I have had some success,
and some problems.
The latest I don't know how to fix....
I am using:
binutils-2.8.1
gcc-2.7.2.1 native compiler
egcs-1.0
newlib-1.8.0
one-egcs.sh
  patches:
binutils-2.8.1-rtems-diff-971221
newlib-1.8.0-diff.980120
  My root source directory is /home/cross
  it contains all of the directories, binutils-2.8.1, egcs-1.0 etc.
 I have had the following problems:
1)  one-egcs.sh :changed
     BINUTILS=gas-971208 to BINUTILS=binutils-2.8.1
2)  My main directory is "/home/cross".
       mkdir build
        cd build
        ../src/configure --target=i386-rtems --prefix=i386-rtems
--with-gnu-as --with-gnu-ld
 gives a directory structure
/home/cross/i386-rtems/bin/
                                          info/
                                          lib/
                                          i386-rtems/include
This doesn't look right to me.. I suspect it is not.
3) Attempted the command: gmake CC=gcc CFLAGS="-O2 -g" all install
    The gcc Makefile caused a segmentation violation when building
target doc:
    cpp.info, et. al. caused the problems.
    I hasitily editted the Makefile ( I know, I should edit Makefile.in
) so that the doc target
    was a no-op in order to proceed.  Retried the command, and
    The make earnestly complained about not finding "ar".
     It was looking for at in  /home/cross/i386-rtems/i386-rtems/bin.
    I did the following:
    mkdir /home/cross/i386-rtems/i386-rtems/bin
    cd  /home/cross/i386-rtems/i386-rtems/bin
    ln -s /home/cross/binutils/ar ar
    everything built just fine.
4)   Inside the build subdirectory,
    cd gcc
    rm -r xlimits.h *.a
    gmake CC=gcc CFLAGS="-O2 -g" libgcc.a all install
     works just fine.
 5)   in /home/cross
       tar -xzf rtems-980219.tgz  works
       mkdir build-rtems
       cd build-rtems
       ../rtems-980219/configure --target=i386-rtems --disable-posix
--enable-rtemsbsp=i386ex --prefix=/home/cross/i386-rtems
    FAILS!
    Reports:   excerpts from config.log show:
configure:1352: checking for gcc
configure:1429: checking whether the target C compiler (i386-rtems-gcc
) works
configure:1444: i386-rtems-gcc -o conftest    conftest.c  1>&5
../rtems-980219/configure: i386-rtems-gcc: command not found
configure: failed program was:
#line 1439 "configure"
#include "confdefs.h"
void *malloc() { return 0; }
 main(){return(0);}
    collect2: cannot find `ld'
  So, I changed the PATH environment variable to include
  rerunning configure...
) works
collect2: ld returned 33 exit status
 main(){return(0);}
supplying the following link in /home/cross/i386-rtems/bin:
 ld -> /home/cross/i386-rtems/lib/gcc-lib/i386-rtems/egcs-2.90.21/ld
 does nothing.
    I am stumped.
Type: text/x-vcard
Desc: Card for Erik Ivanenko
URL: <http://lists.rtems.org/pipermail/users/attachments/19980305/458aa622/attachment.vcf>
