Upgrading at last!
Chris Johns cjohns at plessey.com.au
Wed Mar 4 22:53:27 UTC 1998
Erik Ivanenko wrote:
> I am about to begin rebuilding my development environment.  So far, I
> have installed the "Linux Universe" version. It's the UNIFIX version.
> This version comes with gcc 2.7.2.1 as the stock compiler.
> Should I replace this with egcs prior to building the cross-compiler? or
> , should I just look at the egcs as source for a cross-compiler build? (
> In all previous cross-compiler builds, I always built the latest C
> compiler first.)
I am using RedHat 4.0->5.0 on various machine with various RPM
upgrades.
I use the --prefix parameter with configure to keep EGCS away from the
stock compiler provided by RedHat. I sometimes need to upgrade the
kernel and the stock compiler is best for this job.
You should use a native egcs compiler to build an egcs cross-compiler.
> Should I also install the cpp-libs?
This will depend on the target you are running on. The egcs STL lib
uses exceptions. Think most targets are supported but have never tried
on the 68k processors I use.
What I am not too sure about with the C++ libs in EGCS is what is
GLP/LGPL and what is not ?
Regards
 Chris Johns  Networks, Plessey Asia Pacfic Pty. Ltd.
  mailto:ccj at acm.org    mailto:cjohns at plessey.com.au
