more rtems/powerpc/simulator info
Brendan Simon
brendan at dgs.monash.edu.au
Thu Nov 5 11:35:41 UTC 1998
The simulator barfs when trying to disable instruction cache and data
cache.
Does the simulator support this or do I have to conditionally compile
this code out. What if it is a a startup file library ??
Brendan Simon.
------PREVIOUS MESSAGE-------------
I am trying to use RTEMS with the powerpc simulator that is configured
into GDB. I can get the simulator to run some intstructions but it
barfs when trying to access special purpose registers. I am compiling
code for the MPC860 using the -mcpu=860 in the GCC command line.
Do I have to specify something similar to let the powerpc simulator know
what architecture it is supposed to simulate ?
Are there any docs available on the simulator besides the tiny bits that
are in the GDB manual ?
Brendan Simon.
