Building 4.5.0 beta1c
Boris V. Guzhov borg at int.spb.ru
Wed Apr 12 09:30:56 UTC 2000
Hi all!
My host is Linux RedHat 6.0
My target - i386.
After running of the bit_rtems  Script I see following message error :
/opt/rtems/bin/i386-rtems-gcc --pipe -B../../../../../../ts_386ex/lib/ -spec
bsp_specs -qrtems -g -Wall -ansi -fasm  -O4      -msoft-float -mno-fp-ret-in
-387     -c -DNOSIGNAL -DCYGNUS -DNOMAIN  -o o-optimize/paranoia.o
../../../../../../../rtems-4.5.0-beta1c/c/src/tests/samples/paranoia/paranoi
a.c
bsp_specs -qrtems   -msoft-float -mno-fp-ret-in-387    -g -Wall -ansi -fasm
 -O4     -o o-optimize/paranoia.elf  o-optimize/init.o
-optimize/paranoia.o  -lm o-optimize/paranoia.o: In function `paranoia':
/src/rtems.4.5.0/tools/build-i386-rtems/i386-rtems/c/ts_386ex/tests/samples/
paranoia/../../../../../../../rtems-4.5.0-beta1c/c/src/tests/samples/paranoi
a/paranoia.c:353: undefined reference to `__adddf3'
<about 100 lines is skipped>
a/paranoia.c:2114: undefined reference to `__ltdf2'
collect2: ld returned 1 exit status
gmake[5]: *** [o-optimize/paranoia.exe] Error 1
gmake[5]: Leaving directory
`/src/rtems.4.5.0/tools/build-i386-rtems/i386-rtems/c/ts_386ex/tests/samples
/paranoia'
gmake[4]: *** [all-recursive] Error 1
gmake[4]: Leaving directory
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory
`/src/rtems.4.5.0/tools/build-i386-rtems/i386-rtems/c/ts_386ex/tests'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory
`/src/rtems.4.5.0/tools/build-i386-rtems/i386-rtems/c/ts_386ex'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory
`/src/rtems.4.5.0/tools/build-i386-rtems/i386-rtems/c'
gmake: *** [all-recursive] Error 1
My user.cfg file:
BINUTILS=binutils-2.9.5.0.24
GCC=gcc-2.95.2
NEWLIB=newlib-1.8.2
GDB=gdb-4.18
BUILD_DOCS=yes
BUILD_OTHER_LANGUAGES=no
INSTALL_POINT=/opt/rtems
RTEMS=rtems-4.5.0-beta1c
ENABLE_RTEMS_POSIX=yes
ENABLE_RTEMS_ITRON=no
ENABLE_RTEMS_MP=no
ENABLE_RTEMS_CXX=yes
ENABLE_RTEMS_TESTS=no
ENABLE_RTEMS_TCPIP=no
ENABLE_RTEMS_RDBG=yes
ENABLE_RTEMS_MAINTAINER_MODE=no
Thanks in advance for any help you might be able to provide me.
Boris Guzhov,
St.Petersburg, Russia
