How to build rtems-4.5.0-beta1c on solaris2.6 + SPARC
Serrae at tsainc.com
Thu Apr 13 14:58:52 UTC 2000
Hello folks,
With the help of some folks (Joel Sherril, Adrian Bocaniciu, etc) I was
able to overcome some hurdles:
1) `bit_rtems target', where target is {i386-elf, etc.}, was failing
with some weird stuff. Partial fix is
to do `export LIB=; export CC=gcc; bit_rtems target' This fixed
the above problem (which said:
"...compiler can't create executable.").
2) Then, came "... no rule to make target ftpd." This is due to a
buggy Makefile.in in
${prefix}/tools/rtems-4.5.0-beta1c/c/src/libnetworking/include,
where prefix is of your
choosing. Here is the fixed Makefile.in
(See attached file: Makefile.in)
3) Last, but not least, I ran out of disk space while compiling, so
was not able to build everything.
Good luck.
Sincerely,
Efren
Efren Serra
Software Engineer
Systems Solutions Group
Transaction Systems Architects, Inc.
218 South 108th Avenue
Omaha, NE 68154
Phone: 402-697-2267
FAX: 402-333-9725
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20000413/d0767929/attachment.obj>
