How to run i386-rtemself examples/tests without i386-rtemself-run
Serrae at tsainc.com
Thu Apr 13 19:07:35 UTC 2000
Hello folks,
After I did `bit i386-elf' and got all my cross-compiler tools built. I
realized that i386-rtemself-run was not in the bin directory. Is
this fine? How do I run the examples/tests? Also, After doing
i386-rtemself-gdb and target exec bsp_sp.exe, run failed with the
output:
eserra at sun250$ i386-rtemself-gdb
GNU gdb 4.18
Copyright 1998 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you
are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "--host=sparc-sun-solaris2.6
--target=i386-rtemself".
(gdb) target exec hello.exe
(gdb) run
Starting program:
/export/home/u1/eserra/projects/rtems/tools/build-i386-elf-rte
ms/pc386/tests/hello.exe
Don't know how to run. Try "help target".
(gdb)
Thanking you in advance.
Sincerely,
Efren
Efren Serra
Software Engineer
Systems Solutions Group
Transaction Systems Architects, Inc.
218 South 108th Avenue
Omaha, NE 68154
Phone: 402-697-2267
FAX: 402-333-9725
