How to build the GDB stub Floppy for PC386 target?
Quality Quorum qqi at world.std.com
Fri Apr 14 11:59:52 UTC 2000
On Thu, 13 Apr 2000, Boris V. Guzhov wrote:
> Hi All!
> I have:
> - Linux Red Hat 6.0 host
> - pc486 target (usual computer)
> I build the "Hello world" simple application.
> How to build the GDB stub Floppy for target?
1. Read c/src/lib/libbsp/i386/pc386/HOWTO
> How to load the my application  in my target with usage of the
> I386-rtems-gdb?
2. Add following fragment to the init task
#if 1
  /* Init GDB glue  */
  if(BSPConsolePort != BSP_UART_COM2)
       * If com2 is not used as console use it for
       * debugging
      i386_stub_glue_init(BSP_UART_COM2);
  else
      /* Otherwise use com1 */
      i386_stub_glue_init(BSP_UART_COM1);
  /* Init GDB stub itself */
  set_debug_traps();
   * Init GDB break in capability,
   * has to be called after
   * set_debug_traps
  i386_stub_glue_init_breakin();
  /* Put breakpoint in */
  breakpoint();
#endif  /* 0 */
> Any information where to start looking ?
> Boris Guzhov,
> St.Petersburg, Russia
Thanks,
Aleksey
