How to run i386-rtemself examples/tests without i386-rtemself-run
Quality Quorum qqi at world.std.com
Fri Apr 14 12:02:43 UTC 2000
On Thu, 13 Apr 2000 Serrae at tsainc.com wrote:
> Hello folks,
> After I did `bit i386-elf' and got all my cross-compiler tools built. I
> realized that i386-rtemself-run was not in the bin directory.     Is
> this fine?  How do I run the examples/tests?  Also, After doing
> i386-rtemself-gdb and target exec bsp_sp.exe, run failed with the
> output:
> eserra at sun250$ i386-rtemself-gdb
> GNU gdb 4.18
> Copyright 1998 Free Software Foundation, Inc.
> GDB is free software, covered by the GNU General Public License, and you
> are
> welcome to change it and/or distribute copies of it under certain
> conditions.
> Type "show copying" to see the conditions.
> There is absolutely no warranty for GDB.  Type "show warranty" for details.
> This GDB was configured as "--host=sparc-sun-solaris2.6
> --target=i386-rtemself".
> (gdb) target exec hello.exe
> (gdb) run
> Starting program:
> /export/home/u1/eserra/projects/rtems/tools/build-i386-elf-rte
> ms/pc386/tests/hello.exe
> Don't know how to run.  Try "help target".
> (gdb)
> Thanking you in advance.
It seems like you are trying to run RTEMS image on your host :).
Read c/src/lib/libbsp/i386/pc386/HOWTO.
> Sincerely,
> Efren
> Efren Serra
> Software Engineer
> Systems Solutions Group
> Transaction Systems Architects, Inc.
> 218 South 108th Avenue
> Omaha, NE 68154
> Phone: 402-697-2267
> FAX: 402-333-9725
Thanks,
Aleksey
