invalid multilib selection on m68k/coldfire+msoft-float
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Apr 17 13:32:08 UTC 2000
GCC Version: 2.95.2
Target: m68k-rtems (equivalent to m68k-elf)
behavior is probably also in m68k-coff and m68k-aout.
Test file is main.c:
int main(int argc, char **argv)
strlen( "invoke something in libc" );
Description:
Invoking gcc with -mXXX -msoft-float where -mXXX is a CPU model
without floating point support results in the wrong library
being linked against. The following illustrates this on the
m68000
bash-2.03$ m68k-rtems-gcc -m68000 -msoft-float main.c -Wl,-t
/opt/rtems/m68k-rtems/bin/ld: warning: cannot find entry symbol _start;
defaulting to 80000074
/opt/rtems/m68k-rtems/bin/ld: mode m68kelf
/opt/rtems/m68k-rtems/lib/crt0.o
/tmp/ccKGcp5T.o
(/opt/rtems/m68k-rtems/lib/libc.a)strlen.o
Notice that the libc.a is the default m68020+hardware floating point
one.
If you drop the -msoft-float, then it selects the correct library.
bash-2.03$ m68k-rtems-gcc -m68000 main.c -Wl,-t
/opt/rtems/m68k-rtems/lib/m68000/crt0.o
/tmp/cc0Weu0t.o
(/opt/rtems/m68k-rtems/lib/m68000/libc.a)strlen.o
As best I can tell, the -m68000 flag can be replaced with any
68000-class CPU
flag which results in the following combinations also linking against
the
wrong library
-mc68000
-m5200
-m68302
-m68332
-mcpu32
joel at OARcorp.com On-Line Applications Research
