i960/FreeBSD was Re: Here's the next one... :-(
Mon Apr 17 20:18:59 UTC 2000
Robert Gordon wrote:
> So, from the RPM comment may I assume that no
> one has tried to build this puppy on FreeBSD ?
> Should I switch to a Linux platform ?
> attached is the current 'problem' :-S
What version of what are you using?  RTEMS, tools, etc.  RTEMS has been
built on FreeBSD systems.
> ____________________________________________
> Robert Gordon -  Technical Staff.
> Power Micro Research,  Austin  Texas.
> (512) 257-3031 Ext. 441.
>    bug    Type: unspecified type (application/octet-stream)
>       Encoding: quoted-printable
