Setting build parameters for a sub-tree of RTEMS sources
John M. Mills
jmills at tga.com
Mon Apr 24 18:21:15 UTC 2000
Hi, Joel -
Thanks for the note.
On Mon, 24 Apr 2000, Joel Sherrill wrote:
> Is -O4 allowed to reorder on the SH-2? If so, it is possible that
> executing the statements in the order presented by the source is
> incorrect and the reordered version is correct by the HW.
I don't know where to check this with GCC docs, but I think the answer is
'yes', because the '-O4' output has reversed the order in which the two
exported functions of my code module appear in the assembly language
output. This is the version which works. #8-P)
> Is read8() a macro or subroutine?
> > '#define read8(addr) (*(volatile unsigned8 *) (addr))'
They're macros. 'read*' effectively typecasts the right-side argument of
an assignment, so you can just define a CPU register in terms of its
[memory-space] address:
'#define SOME_ONCHIP_REGISTER 0xffff????'
and access it with:
> > 'temp8 = read8(SOME_ONCHIP_REG);'
'write*' versions are macros for type-case assignment operations - left
and right sides both appear. You can thus read or write to different
register widths with a single register-address definition, provided this
is appropriate for the hardware.
> Have you looked at the
> assembly generated at both levels to see if some obvious
> set of operations is differently? I know that when you are
> missing volatile, the difference is amazingly clear this way.
Yes: I can follow the '-O4' output fairly well -- we're just talking about
3 read/mask/write sequences here -- but '-O1' is dense, convoluted and
loop-oriented. I haven't puzzled it out.
I can try again with 'volatile', which doesn't solve the problem, in case
it would be informative.
NATURALLY ---
I want to find out if I have a usage or coding error here, and fix it.
BUT --- I think the selective-optimization question still obtains, because
I may yet inherit or write other code with similar sensitivities: I was
just lucky enough to find this case in a short, well-contained routine. I
fear taking a long time to find this type problem in a more deeply buried
part of the code.
The three attachments to this note are for true masochists, but I would
be very happy to receive feedback from anyone who looks at them:
1) the original C code: 'hw_init.c'
2) assembly code obtained with '-O4' optimization, which works, and
3) assembly code obtained with '-O1' optimization, which doesn't work.
I chopped the assembly listings down to the tiny fraction which is
corresponds to my source, and may have tossed out some essentials -- let
me know that's true.
Let me know also if I should spare the list this gorey postmortem, and
just post a conclusion, presuming I get to one.
Thanks for any comments -
John Mills
Sr. Software Engineer
TGA Technologies, Inc.
100 Pinnacle Way, Suite 140
Norcross, GA 30071-3633
e-mail: jmills at tga.com
Phone: 770-441-2100 ext.124 (voice)
770-449-7740 (FAX)
Desc: 'hw_init.c' original source
URL: <http://lists.rtems.org/pipermail/users/attachments/20000424/d2ec31ed/attachment.obj>
[... entire preamble elided ...]
.align 4
.def _bsp_hw_init; .val _bsp_hw_init; .scl 2; .type 041; .endef
.global _bsp_hw_init
_bsp_hw_init:
.def .bf; .val .; .scl 101; .line 78; .endef
.ln 2
.ln 28
mov.l r14, at -r15
mov.w L54,r3
mov.w @r3,r1
.ln 29
mov.w L55,r2
.ln 28
extu.w r1,r1
.ln 29
or r2,r1
.ln 30
mov.w r1, at r3
.ln 33
mov.w L56,r2
mov #0,r1
mov.w r1, at r2
.ln 36
add #-6,r2
mov.w @r2,r1
extu.w r1,r0
.ln 37
or #32,r0
.ln 38
mov.w r0, at r2
.ln 28
mov r15,r14
.ln 40
mov r14,r15
rts
mov.l @r15+,r14
.align 1
L54:
.short -31816
L55:
.short 2048
L56:
.short -31814
.def .ef; .val .; .scl 101; .line 40; .endef
.def _bsp_hw_init; .val .; .scl -1; .endef
.align 4
.def _early_hw_init; .val _early_hw_init; .scl 2; .type 041; .endef
.global _early_hw_init
_early_hw_init:
.def .bf; .val .; .scl 101; .line 55; .endef
mov.l r14, at -r15
mov r15,r14
.ln 20
mov r14,r15
rts
mov.l @r15+,r14
.def .ef; .val .; .scl 101; .line 20; .endef
.def _early_hw_init; .val .; .scl -1; .endef
.align 4
_early_hw_init:
.ln 20
mov.l r14, at -r15
mov r15,r14
mov r14,r15
rts
mov.l @r15+,r14
.align 4
_bsp_hw_init:
.ln 2
.ln 28
mov.l r14, at -r15
mov r15,r14
mov.w L54,r3
mov.w @r3,r1
extu.w r1,r1
.ln 29
mov.w L55,r2
or r2,r1
.ln 30
mov.w r1, at r3
.ln 33
mov.w L56,r2
mov #0,r1
mov.w r1, at r2
.ln 36
add #-6,r2
mov.w @r2,r1
extu.w r1,r0
.ln 37
or #32,r0
.ln 38
mov.w r0, at r2
.ln 40
mov r14,r15
rts
mov.l @r15+,r14
.align 1
L54:
.short -31816
L55:
.short 2048
L56:
.short -31814
