RTEMS_MAKEFILE_PATH
Thu Apr 27 16:54:52 UTC 2000
Serrae at tsainc.com wrote:
> Hello folks,
> What do I set the above environment variable to when compiling to
> i386-rtemself target?  Thanks.
It is only needed to be set when you compile an application using
the RTEMS makefile scheme.  It is set to something like this:
RTEMS_MAKEFILE_PATH=${prefix}/${BSP}
where prefix is the install point and BSP is your BSP.
> -efren-
> Efren Serra
> Software Engineer
> Systems Solutions Group
> Transaction Systems Architects, Inc.
> 218 South 108th Avenue
> Omaha, NE 68154
> Phone: 402-697-2267
> FAX: 402-333-9725
