Problem Building Rtems-4.5.0-beta1c for gen68360
Charles-Antoine Gauthier
charles.gauthier at nrc.ca
Mon Apr 3 16:17:24 UTC 2000
Gus Paolone wrote:
> Hi All;
> Since my last posting, I've now been able to start building RTEMS
> itself. However when it starts building the hello sample application the
> linker fails looking for "crti.o". The source for this file I could not
> find, and as I understand its related to start-up code. I also found in
> bsp_specs crti.o being specified.
> Can somebody please explain to me where I can find crti.o? And how does
> the bsp_spec file work?
> Any help on this problem would be greatly appreciated.
> Gus.
crti.o, crtn.o, crtbegin.o and crtend.o all come from gcc. You should
have gotten them when you built gcc 2.95.2 with the latest patches from
OAR. The target is either m68k-rtems or m68k-rtemself. Both targets are
equivalent and build a m68k/ELF compiler. The rules to build the extra
bits are in egcs/gcc/config/m68k/t-crtstuff. Your egcs/gcc/configure.in
file should have a paragraph that looks like:
m68k-*-rtemself*|m68k-*-rtems*)
tmake_file="m68k/t-m68kbare t-rtems m68k/t-crtstuff"
tm_file=m68k/rtemself.h
extra_headers=math-68881.h
float_format=m68k
What would you like to know about the bsp_spec file? Specs are discussed
in the latest gcc manuals. You can do an 'info gcc' and look under
Invoking gcc
Spec Files
Essentially, the file states that if the -qrtems flag is thrown, it
should use the specified libraries for linking. The -qrtems file is
specified in the build rules in
rtems/make/compilers/gcc-target-default.cfg.
Institute for Information Technology Institut de technologie de
l'information
National Research Council of Canada Conseil national de recherches du
Canada
