RTEMS 4.0.0 build (Reposted)
Charles-Antoine Gauthier
charles.gauthier at nrc.ca
Wed Apr 5 15:50:21 UTC 2000
Here is my guess at what is happening.
You are building rtems 4.0.0. This version expected isatty to come from
newlib 1.8.1.
You are building newlib 1.8.2. This version is configured to not build
isatty because it will be supplied by RTEMS 4.5.0.
You must either upgrade to rtems 4.5.0 (which is not yet available to
the general public, although a beta is available as
ftp://ftp.oarcorp.com/pub/rtems/betas/rtems-4.5.0-beta/rtems-4.5.0-beta1c.tgz,
or roll back to newlib 1.8.1.
Tony Butt wrote:
> Please excuse what may be an ignorant question, but I have only just joined
> this group, and I have a RTEMS build problem that I cannot easily resolve.
> Also please excuse the repost, if this question has already been answered, but I
> had trouble with my mailing list subscription. If you have already answered, I
> have not seen it, so please resend to me (direct if you wish).
> I have been trying to install RTEMS 4.0.0 using the following support tools:
> Newlib 1.8.2
> egcs 1.1.2
> binutils 2.9.1, with the RTEMS patch applied.
> Configured for an m68k target, genm68302 BSP
> I have tried 2 seperate build platforms, A Windows NT4 SR6 PC, using Cygnus
> Developers Kit v20, and a HP workstation, using HPUX 10.20.
> My problem is that the link step for all of the test programs fails with an
> undefined reference to isatty. Both build platforms have the same problem.
> Do I need to provide a stub for isatty, should it be in the BSP, or should
> newlib be providing this for me?
> The output from the build of hello.exe is shown here...
> cd hello; gmake all
> /usr/local/egcs-1.1.2-binutils-2.9.1-newlib-1.8.2/m68k-rtems/bin/m68k-rtems-gcc
> --pipe -m68302 -msoft-float -Wall -ansi -fasm -g -B/usr/local/rtems/tools/build
> -m68k-rtems/gen68302/lib/ -specs bsp_specs -qrtems -O4 -fomit-frame-pointer
> -o o-gen68302/hello.exe o-gen68302/init.o /usr/local/rtems/tools/build-m68k-r
> tems/gen68302/lib/no-dpmem.rel /usr/local/rtems/tools/build-m68k-rtems/gen68302/
> lib/no-event.rel /usr/local/rtems/tools/build-m68k-rtems/gen68302/lib/no-msg.rel
> /usr/local/rtems/tools/build-m68k-rtems/gen68302/lib/no-mp.rel /usr/local/rtems
> /tools/build-m68k-rtems/gen68302/lib/no-part.rel /usr/local/rtems/tools/build-m6
> 8k-rtems/gen68302/lib/no-signal.rel /usr/local/rtems/tools/build-m68k-rtems/gen6
> 8302/lib/no-timer.rel /usr/local/rtems/tools/build-m68k-rtems/gen68302/lib/no-rt
> mon.rel /usr/local/rtems/tools/build-m68k-rtems/gen68302/lib/libtest.a
> /usr/local/egcs-1.1.2-binutils-2.9.1-newlib-1.8.2/m68k-rtems/m68k-rtems/lib/libc
> .a(makebuf.o): In function `__smakebuf':
> makebuf.c:93: undefined reference to `isatty'
> collect2: ld returned 1 exit status
> gmake[4]: *** [o-gen68302/hello.exe] Error 1
> gmake[4]: Target `all' not remade because of errors.
> I've looked at the source code for newlib, and seen that 'isatty' is normally
> provided there, but it is not being built for me.
> Thanks in advance...
> Tony Butt
> E-Mail: tjb at cea.com.au
> Date: 03-Apr-00
> Time: 08:28:05
> Tony Butt Phone (02) 62130195
> CEA Technologies
Institute for Information Technology Institut de technologie de
l'information
National Research Council of Canada Conseil national de recherches du
Canada
