Error building 4.5.0 beta1c.
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Fri Apr 7 14:32:27 UTC 2000
Charles-Antoine Gauthier wrote:
> I think that Chill and Objective-C cannot be built as cross-compilers.
That highly depends on the target.
chill, objc etc. can be built for most of RTEMS's gcc toolchains (IIRC:
i386, m68k, ppc, sh, sparc), but not for all (eg.: i960). For some
targets, even gcc doesn't build (eg. hppa-1.0).
> You may need 'make LANGUAGES="c c++"' also. I had some problems with
> some past releases of gcc honoring the --enable-languages=.
'make LANGUAGES=..' is depredicated and doesn't work with gcc-2.95.2
anymore.
configure '--enable-languages=c,c++'
should work (Note the quotes).
(cf. rtems-4.5.0-xxx/scripts/gccnewlib/gccnewlib_c_only.spec.in)
Ralf.
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung (FAW)
Helmholtzstr. 16, 89081 Ulm, Germany Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de FAX: +49/731/501-999
http://www.faw.uni-ulm.de
