GDB build failure under Cygwin environment !
David J. Fiddes D.J at fiddes.surfaid.org
Fri Apr 7 21:26:21 UTC 2000
Hi,
>It seems the Cygwin lacks the term library, but where to get
>the library and how to add it to Cygwin ?
Yes. I'm aware of this problem. You can do what I'm about to and grab it
from the http://sourceware.cygnus.com/cygwin/ which has the appropriate
libraries in its Ports sections. You might need to do something about an
/etc/termcap to keep things happy.
>(On the FTP site, there are some RPMs already built for i386
>under cygwin directory, but there are no GDB for any processor
>and no RPMs for powerpc. I hope if somebody could upload all
>these missing tools to the FTP site !)
I'm not sure what's happened to the powerpc RPMS at all. I certainly built
them! The GDB RPMS will probably happen but only in time for the full
release of 4.5.0. The tools take so long to build and upload that I'm not
too keen to repeat the excercise unless I absolutely have to ;)
hope this helps,
Dave
