How to build the GDB stub Floppy for PC386 target?
cmartine
cmartine at cluster-research.com
Thu Apr 13 17:28:43 UTC 2000
Check underneath the pc386_lilo directory (its a linux boot loader)
and modify the Makefile.inc . There is a line that points to your
binary you just built.
RTEMS_IMAGE =
/export/d0/RTOS/TARGET/tests/samples/unlimited/o-optimize/test.exe
Then just run make clean , make
youll find zImage .
use dd if=./zImage of=/dev/fd0
to copy to your floppy.
"Boris V. Guzhov" wrote:
> Hi All!
> I have:
> - Linux Red Hat 6.0 host
> - pc486 target (usual computer)
> I build the "Hello world" simple application.
> How to build the GDB stub Floppy for target?
> How to load the my application in my target with usage of the
> I386-rtems-gdb?
> Any information where to start looking ?
> Boris Guzhov,
> St.Petersburg, Russia
