C compile problem
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Apr 17 20:21:07 UTC 2000
Did this fix it? I want to cut another beta and this needs to go in.
--joel
Charles-Antoine Gauthier wrote:
> 'or' is a reserved keyword in C++. Patches for this problem have already
> been submitted as part of work to fuse the MBX860 and MBX821 BSPs and
> PPC860 and PPC821 processors. Because of the substantial reorganization,
> it was decided that the change would go in after RTEMS 4.5.0 was
> released. For now, in
> rtems/c/src/lib/libcpu/powerpc/mpc860/include/mpc860.h, just do this:
> * Memory controller registers
> typedef struct m860MEMCRegisters_ {
> rtems_unsigned32 _br;
> rtems_unsigned32 _or;
> } m860MEMCRegisters_t;
> I quickly scaned of the eth_comm BSP files. It seems that the fields are
> not used, so the above change may be the only one that is required. If
> you are not using the eth_comm BSP, or if I missed finding the usage of
> the fields, you will have to make the corresponding change in the source
> files.
> Patrick.VARNEY at syntegra.bt.co.uk wrote:
> > When I try to compile a C++ file that includes mpc860.h which includes a
> > structure which defines a field called 'or', the RTEMS GNU C++ compiler
> > fails reporting 'empty component declaration'. However, the RTEMS GNU C
> > compiler doesn't fail. Is there a way round this, other than turning the
> > file into a C file ?
> > Patrick Varney
> > Tel. 01932 773576
> > Mob. 0771 8046 750
> > email patrick.varney at syntegra.bt.co.uk
> Institute for Information Technology Institut de technologie de
> l'information
> National Research Council of Canada Conseil national de recherches du
> Canada
joel at OARcorp.com On-Line Applications Research
