Address error exception
Eric Norum
eric at cls.usask.ca
Fri Apr 21 15:54:08 UTC 2000
"Alexey S. Fadeyev" wrote:
> Hello.
> Can anyone suggest why RTEMS throw exception as soon as I put packet in
> ether_input?
> Target - mips64orionel
> CPU - p4650
> * Check our list of addresses, to see if the packet is for us.
> for (ia = in_ifaddr; ia; ia = ia->ia_next) {
> 9f04b338: 3c069f07 lui $a2,0x9f07
> 9f04b33c: 8cc63638 lw $a2,13880($a2)
> 9f04b340: 8fa80028 lw $t0,40($sp)
> 9f04b344: 10c00017 beqz $a2,9f04b3a4 <ip_input+0x348>
> 9f04b348: 00c0182d 0xc0182d
> 9f04b34c: 8d040010 lw $a0,16($t0)
> #define satosin(sa) ((struct sockaddr_in *)(sa))
> Cause Register
> 00007810 i.e. 0111 1000 0(001 00)00 Exc Code equals 4 - Address
> Error Exception
> EPC
> 9f04b34c
Address Error Exception? Could this be because you're trying to access
a 32-bit value that isn't on a 32-bit boundary. IMHO the designers of
Ethernet made a *major* blunder in making the ethernet header 14 bytes
long since an ethernet frame aligned on a 32-bit boundary has all the
TCP/UDP/IP header information offset by 2 bytes from a 32-bit boundary.
If this is the problem you'll have to either memcpy the frame so that
the IP header is on a 0 mod 4 address, or arrange for the transfer from
the ethernet controller to memory to begin on a 2 mod 4 address.
Eric Norum eric at cls.usask.ca
Canadian Light Source Phone: (306) 966-6308
University of Saskatchewan FAX: (306) 966-6058
Saskatoon, Canada.
