About linkcmds
Aaron Xinhuan Liu
xliu at csr.UVic.CA
Fri Apr 21 14:33:02 UTC 2000
Thank you for your help.
I'd like to place the RTEMS entry point to the second long word of the image I
use.
Aaron
Ian Lance Taylor wrote:
> Date: Fri, 21 Apr 2000 15:04:04 +0100
> From: Aaron Xinhuan Liu <xliu at csr.UVic.CA>
> Does anyone know how to assign a function address to a variable in the
> linkcmds script ? Is it ok if I use " startAddr = &start ; "? Thanks.
> That won't work.
> In the linker script language, symbols represent an address in virtual
> memory. Assigning to a symbol means setting it to an address in
> virtual memory. So `startAddr = start;' is more likely to be correct.
> What are you trying to do?
> Ian
