4.5.0-beta2
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Apr 27 18:56:09 UTC 2000
I can't see how this error is happening. Something is
fundamentally different. How about some background info?
+ host machine/OS?
+ what version of make?
This looks like an issue with use non-GNU makes.
FYI somewhere rtems-user at ORAcorp.com (not OARcorp.com) has slipped in.
James Housley wrote:
> Joel Sherrill wrote:
> > Does user.cfg to point to the right
> > version of RTEMS?
> Yes. I had to make two change to make it work:
> rtems-4.5.0-beta2/configure
> --- configure.orig Thu Apr 27 14:40:16 2000
> +++ configure Thu Apr 27 09:21:05 2000
> @@ -1210,7 +1210,7 @@
> # List all subdirectories to be compiled for the target here
> -target_subdirs="c"
> +target_subdirs="m68k-rtems/c"
> rtems-4.5.0-beta2/c/src/make/configure
> --- configure.orig Thu Apr 27 14:43:11 2000
> +++ configure Thu Apr 27 09:21:20 2000
> @@ -3413,7 +3413,7 @@
> EOF
> cat >> $CONFIG_STATUS <<\EOF
> -make $RTEMS_BSP.cache
> +gmake $RTEMS_BSP.cache
> exit 0
> EOF
> chmod +x $CONFIG_STATUS
> The last one probably should be changed to a ${MAKE} ???
> Jim
> The wise man built his network upon U*nx.
> The foolish man built his network upon Windows.
joel at OARcorp.com On-Line Applications Research
