Please help with GDB/PSIM and Redhat Linux
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Aug 1 15:09:02 UTC 2000
Try this patch to use a more reasonable default configuration:
bash$ cvs diff -u c/src/libmisc/dummy
cvs server: Diffing c/src/libmisc/dummy
Index: c/src/libmisc/dummy/dummy.c
RCS file: /usr1/CVS/rtems/c/src/libmisc/dummy/dummy.c,v
retrieving revision 1.3
diff -u -r1.3 dummy.c
--- c/src/libmisc/dummy/dummy.c 2000/06/12 15:00:07 1.3
+++ c/src/libmisc/dummy/dummy.c 2000/08/01 15:07:51
@@ -26,7 +26,9 @@
/* configuration information */
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_TASKS 10
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
#define CONFIGURE_INIT
This is more like what is used to be around Dec 1999.
Now the defaults are lower to save memory.
The call to "boot_card" in psim/start/start.S needs
to pass argc, argv, and environp. See the file
libbsp/m68k/shared/start.S for an example of how this
is supposed to be. I don't see any PPC code that
is setting it up properly. The best I see at first
glance is 0's for argc/argv -- nothing for environp.
environp must be passed in to make setenv work.
Hoang Ngo wrote:
> I used the same psim-gdb script for both environments.
> The on under slackware works but not the one under redhat.
> Here is the content of psim_tree.hngo
> /#address-cells 2
> /openprom/options/oea-memory-size 8388608
> Here is the result of running examples/ncurses/rain.exe
> core_find_mapping() - access to unmaped address, attach a default map to
> handle this - addr=0x38392d31 nr_bytes=0x1 processor=0x401a5008 cia=0xd828
> The address 0xd828 is in the function <set_curterm>.
> Followed your suggestion, i tried to uncommented some of the devices
> in the psim-gdb script but the simulator doesn;t know about the device
> sem or shm.
> Hoang
> -----Original Message----
> From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
> Sent: Sunday, July 30, 2000 7:04 AM
> To: hoanghngo at home.com
> Cc: rtems-users at OARcorp.com
> Subject: Re: Please help with GDB/PSIM and Redhat Linux
> Hoang Ngo wrote:
> > I ran into a perflexing problem. At home i use Slackware7
> > and rtems-4.5.0-beta3a, and rtems-packages-19991215
> > compiled for GDB/PSIM. All the applications under ncurses
> > directory ran fine (except that the terminal is not displaying
> > what it supposed to). At work i use redhat-6.2 with all the same
> > rtems packages but unable to get the ncurses applications to run.
> > The error message indicates that the applications is accessing
> > an unmapped region of memory (core_find_mapping() - access
> > to unmaped address, attach a default map to handle this -
> > addr=0x38392d31 nr_bytes=0x1 processor=0x401a5008 cia=0xf1dc).
> > If you have any suggestions as what to look for please drop me a line.
> I think this is a matter of either one of two things:
> + You are not starting the simulator with all the device options.
> See the script psim/psim-gdb included with the BSP in the tools
> subdirectory.
> + I am not sure what instruction/inside what function the cia
> is pointing to but it might be an issue that the shared memory
> or semaphore is not being initialized correctly.
> More than likely, it is the first since the shared mem/semapahore
> is mapped to different processor address range. See what the
> psim script does to initialize the simulator.
> > TIA,
> > Hoang
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
