mcp750 code region full was Re: Undefined reference to rtems _bsdnet_config
Hoang Ngo hngo at caspiannetworks.com
Wed Aug 2 22:34:38 UTC 2000
I am just trying to get rid of the error so i added
in alot of libs. I'll get rid of some of the libraries
once the error is gone and that will reduce the size
of the image.
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
Sent: Wednesday, August 02, 2000 2:27 PM
To: Hoang Ngo
Cc: 'Efren Serra'; 'rtems-users at oarcorp.com'
Subject: mcp750 code region full was Re: Undefined reference to
rtems_bsdnet_config
> > o-rtmon.rel -ltcl8.4 -lm -lnetworking -lrtemsall -lnetchip
> > /opt/rtems/powerpc-rtems/bin/ld: region CODE is full (o-optimize/rlchk
> > section .
> > rodata)
> > /opt/rtems/powerpc-rtems/bin/ld: section .data [00003000 -> 0000bc0b]
> > overlaps s
This looks like the executable has grown too large to fit into
the space reserved for it in the linkcmds file.  See
lib/libbsp/powerpc/motorola_shared/startup/linkcmds.
FWIW it reserves a LOT of memory ... what are you linking again?
