Undefined reference to rtems_bsdnet_config
OUTWATER vac4050 at cae597.rsc.raytheon.com
Thu Aug 3 20:21:07 UTC 2000
Hoang -
I can't help with the ethernet driver problem, but as far as the tar issue is
concerned, it's mentioned in the README in the "TO-DO" list as something that needs
work.
Basically, I used a method discussed awhile back on the list to tar up an initial
filesystem that contained files required by the network stack and in the case of
tclsh, some tcl scripts as well.  tclsh wants to source some scripts as part of its
startup, and I was trying to make sure that they were there.
When the tarfile is linked, the linker complains, but things still work.  As I
remember, someone took a look at the "http" demo program and cleaned this up.  The
mail list archives would be a good place to look.
I forgot to clean up the part of the makefile that has "elf32-m68k" explicity
specified.  There must be a way for the Makefile to figure out what the object format
is based on the BSP...  Does anyone else know how to do this??
Keith
> Keith -
> I got the latest tclsh.tgz from OARcorp and i am having
> problems compiling the package for mcp750 platform. There
> are a two undefines "RTEMS_BSP_NETWORK_DRIVER_NAME" and
> "RTEMS_BSP_NETWORK_DRIVER_ATTACH". For these, i defined
> them as "#define RTEMS_BSP_NETWORK_DRIVER_NAME "eth1"" and
> "#define RTEMS_BSP_NETWORK_DRIVER_ATTACH "rtems_dec21140_driver_attach""
> to get rid of the problem. The other problem i have is when you created
> a tar file and convert it to elf32-m68k. I changed the format to
> elf32-powerpc
> but objcopy rejected it with a message
> "Output file cannot represent architecture UNKNOWN!".
> A quick look at objcopy shows that it does indeed support elf32-powerpc. My
> assumption is that you want to convert from tar to elf is to include these
> files in as part of the final image. Can you expand on this some more? Was
> it to allow the Tcl interpreter to read these files? And what is the
> mechanism
> that allows tcl to read these files?
> Thanks,
> Hoang
> -----Original Message-----
> From: OUTWATER [mailto:vac4050 at cae597.rsc.raytheon.com]
> Sent: Wednesday, August 02, 2000 2:24 PM
> To: rtems-users at oarcorp.com
> Subject: Re: Undefined reference to rtems_bsdnet_config
> Hoang -
> After I posted the stuff about tcl8.4a, I noticed that on www.scriptics.com
> (TCL's home) that 8.4a is a developer's version.
> I decided to stick to version 8.3 instead.  It's listed as stable, which
> seems
> like a good thing as far as porting is concerned.
> Also, I just uploaded rtems-tcl-8.3.tgz to OAR's ftp site.  This package
> includes a makefile that builds the stripped and debug TCL libs for RTEMS.
> I also uploaded tclsh.tgz  which is patterened after the RTEMS demos. It's a
> work in progress, but it compiles.  The README has a list of TO-DOs.  It
> doesn't
> work for me yet (I get an illegall address exception), but it might work for
> you.
> These packages are in Joel's hands now.  I uploaded them in the hope that
> someone can take them and get them running.  Unfortunately, I don't really
> have
> the time (and I'm definitely not an RTEMS expert).
> Keith
> > I ran into a problem linking tcl8.4 lib with rtems. The error messages is
> > /opt/rtems/bin/powerpc-rtems-gcc --pipe -B/opt/rtems//mcp750/lib/ -specs
> > bsp_spe
> > cs -qrtems -g -Wall -ansi -fasm  -O4 -mmultiple -mstring -mstrict-align
> > -mc
> > pu=750    -Dmain=rlchk   -L /opt/rtems//mcp750/lib    -o o-optimize/rlchk
> > o-opt
> > imize/init.o o-optimize/tclAppInit.o   /opt/rtems//mcp750/lib/no-dpmem.rel
> > /opt/
> > rtems//mcp750/lib/no-mp.rel /opt/rtems//mcp750/lib/no-part.rel
> > /opt/rtems//mcp75
> > 0/lib/no-signal.rel /opt/rtems//mcp750/lib/no-timer.rel
> > o-rtmon.rel -ltcl8.4 -lm -lnetworking -lrtemsall -lnetchip
> > /opt/rtems/powerpc-rtems/bin/ld: region CODE is full (o-optimize/rlchk
> > section .
> > rodata)
> > /opt/rtems/powerpc-rtems/bin/ld: section .data [00003000 -> 0000bc0b]
> > overlaps s
> > ection .text [00003000 -> 000f603f]
> > /opt/rtems/powerpc-rtems/bin/ld: section .got2 [0000bc0c -> 0000bc83]
> > overlaps s
> > /opt/rtems/powerpc-rtems/bin/ld: section .fixup [0000bc84 -> 0000bc8b]
> > overlaps
> > section .text [00003000 -> 000f603f]
> > /opt/rtems/powerpc-rtems/bin/ld: section .got [0000bc8c -> 0000bc9b]
> > overlaps se
> > /opt/rtems/powerpc-rtems/bin/ld: section .sdata [0000bca0 -> 0000c4df]
> > overlaps
> > /opt/rtems//mcp750/lib/libnetworking.a(rtems_glue.o): In function
> > `rtems_bsdnet_
> > initialize':
> /home/hngo/rtos/rtems/tools/build-powerpc-rtems/powerpc-rtems/c/mcp750/libne
> > twor
> king/rtems/../../../../../../rtems-4.5.0-beta3a/c/src/libnetworking/rtems/rt
> > ems_
> > glue.c:207: undefined reference to `rtems_bsdnet_config'
> > I have tried adding various libs in the linking stage but none works. Any
> > suggestions?
> > TIA,
> > Hoang
