configuration
Thu Aug 10 12:56:51 UTC 2000
gerke.kok at tpa-nl.com wrote:
> Hallo,
> see the mailing list. There should be something about the LIB and
> INCLUDE_DIR environment options that are bugging you. You probably have VC
> installed as well.
Right.
Do "env | grep LIB" or simply env.  Look for environment variables set
to
point at Windows tools that have common names.
Also /bin/gcc.exe should be linked to /bin/cc.exe.
> Also I would not hurt to install automake and autoconfig. And perhaps you
> should check the availability of perl in your cygwin instalation...
ALl of this should only be needed if you are editting Makefile.ams or
configure.in's.
> wkr,
> Gerke
> > -----Original Message-----
> > From: D.G.Somerton [mailto:dgsomerton at hunterwatertech.com.au]
> > Sent: Thursday, August 10, 2000 08:29
> > To: rtems
> > Subject: configuration
> > Hello,
> >   I have attempted to configure the v4.5 beta 3 rtems source.
> >   This failed.
> >   I am using cygwin, whose cygwin1.dll file shows v1.1.2, API
> > version 0.21,
> > Build date 2000-06-06 22:20, Product version 1.1.2, Shared
> > Memory Version 3.
> >   I am using NT 4 SP 6
> >   I am using the bash shell.
> >   Here is the tree:
> >   /tools -> the pre-build executables.  = /opt/rtems
> >   /opt/rtems-4.5.0-beta3a  -> the rtems source
> >   /opt/build -> the build directory
> > $cd /opt/build
> > $../rtems-4.5.0-beta3a/configure --target=m68k-rtems
> > --disable-posix --disab
> > le-networking --disable-itron --enable-rtemsbsp=m68k-rtems >z 2>&1
> > Here is 'z'
> > loading cache ./config.cache
> > checking for RTEMS Version... 4.5.0-beta3a
> > checking host system type... i386-pc-cygwin32
> > checking target system type... m68k-unknown-rtems
> > checking build system type... i386-pc-cygwin32
> > checking rtems target cpu... m68k
> > checking for a BSD compatible install... (cached) /usr/bin/install -c
> > checking whether build environment is sane... yes
> > checking whether make sets ${MAKE}... (cached) yes
> > checking for working aclocal... missing
> > checking for working autoconf... missing
> > checking for working automake... missing
> > checking for working autoheader... missing
> > checking for working makeinfo... found
> > checking whether to enable maintainer-specific portions of
> > Makefiles... no
> > checking if the test suites are enabled? ... no
> > checking if cpu m68k is supported... yes
> > creating ./config.status
> > creating Makefile
> > creating tools/Makefile
> > creating make/Makefile
> > creating make/custom/Makefile
> > creating make/Templates/Makefile
> > creating make/compilers/Makefile
> > creating doc/Makefile
> > configuring in tools/build
> > running /bin/sh
> > ../../../rtems-4.5.0-beta3a/tools/build/configure
> > --target=m68k-rtems --disa
> > ble-posix --disable-networking --disable-itron
> > --cache-file=../.././config.cache
> > --srcdir=../../../rtems-4.5.0-beta3a/tools
> > /build
> > loading cache ../.././config.cache
> > Makefiles... no
> > checking for Cygwin environment... no
> > checking for mingw32 environment... no
> > checking for executable suffix... configure: error: installation or
> > configuration problem: compiler cannot create executables.
> > configure: error:
> > ../../../rtems-4.5.0-beta3a/tools/build/configure failed
> > for tools/build
