OR1K tools
Rosimildo da Silva rdasilva at connecttel.com
Mon Aug 14 23:20:33 UTC 2000
Damjan Lampret wrote:
> Needs some fixing, yes.
> >    + libreadline library not found. Under CygWin readline.a is
> >      not installed.
> >      Compiled with the version that came with insight 5.0.
> >      Simulator compiled and linked OK. It seems to reach
> >      some error when executing 'testbench/dhry.or32'.
> Looks like something is wrong with COFF routines (I wrote them in a hurry,
> really ugly). Anyway try to load "assembly" files. Like
> testbench/dhry.or32.s. Also you can try to load testbench/uos/uos.or32
> (but this one is also coff).
Ok. I'll try this later.
> > 2. Binutils
> >    + Do we have elf support ? It seems to support coff only now.
> Coff only so far. Is coff enough for a start?
Yes, I believe so. The problem is that most of the toolchains are
ELF based. You would need ELF for complete C++ support.
As long as we do not spend too much time with these COFF
tools, it'll be ok.
> >   + error during compilation:
> This one was already fixed but the patch got lost somewhere. I'll do it
> again.
Let me know if you find that patch. :-)
Anyway, I am waiting for Joel to get something going
for Linux first, then I will take the sources from there
to generate the tools for CygWin. Unless, I hear that
he is genrerating the toolset for CygWin as well. :-)
Regards,
Rosimildo da Silva            rdasilva at connectel.com
ConnectTel, Inc.              Austin, TX -- USA
Phone : 512-338-1111          Fax : 512-918-0449
Mobile: 512-632-7579
Company Page: http://www.connecttel.com
Home Page: http://members.xoom.com/rosimildo/
