i386-rtems
Damjan Lampret
lampret at opencores.org
Tue Aug 15 07:05:11 UTC 2000
Hi,
I have installed all i386-rtems tools on my i386 RH Linux 6.2 box. I
encounter the following problems:
# rtems-ss-20000811/configure --target=i386-rtems --enable-rtemsbsp=pc386
--disable-posix --disable-itron
/opt/rtems/bin/i386-rtems-gcc --pipe -B../../../../../pc386/lib/ -specs
bsp_specs -qrtems -g -Wall -ansi -fasm -c -O4
-o o-optimize/imfs_eval.o
../../../../../rtems-ss-20000811/c/src/lib/libc/imfs_eval.c
../../../../../rtems-ss-20000811/c/src/lib/libc/imfs_eval.c: In function
`IMFS_evaluate_sym_link':
../../../../../rtems-ss-20000811/c/src/lib/libc/imfs_eval.c:163: `node'
undeclared (first use in this function)
../../../../../rtems-ss-20000811/c/src/lib/libc/imfs_eval.c:163: (Each
undeclared identifier is reported only once
../../../../../rtems-ss-20000811/c/src/lib/libc/imfs_eval.c:163: for each
function it appears in.)
gmake[4]: *** [o-optimize/imfs_eval.o] Error 1
gmake[4]: Leaving directory
`/usr/src/build-rtems/i386-rtems/c/pc386/lib/libc'
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory `/usr/src/build-rtems/i386-rtems/c/pc386/lib'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory `/usr/src/build-rtems/i386-rtems/c/pc386'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/usr/src/build-rtems/i386-rtems/c'
make: *** [all-recursive] Error 1
I think I'll try to build for some other architectures (looks I don't have
much luck with i386).
regards,
Damjan
