i386-rtems
Damjan Lampret lampret at opencores.org
Tue Aug 15 09:37:21 UTC 2000
On Tue, 15 Aug 2000, Ralf Corsepius wrote:
> Damjan Lampret wrote:
[cut]
> > # rtems-ss-20000811/configure --target=i386-rtems --enable-rtemsbsp=pc386
> > --disable-posix --disable-itron
> There are several potential issues with this command line:
> 1. Are you having the source-tree in a subdirectory of you
> build-directory? This might interfere with building, because the
> process of building creates directories. Please use a separate and
> empty build-directory instead.
Actually I do. OK, I'll try emptry build directory.
> 2. Not specifying --prefix means installing to /usr/local. This
> should not hurt wrt. rtems, but might interfere with other packages,
You just gave me an idea. Instead of using --prefix-program I put
/opt/rtems/bin in my PATH variable (so that configure can find correct
tools). Should I rather use --prefix-program instead of setting my PATH?
Thanks for the help. I appreciate it.
regards,
Damjan
