Antwort: Re: Baking a i386-rtems image
Thu Aug 24 12:17:27 UTC 2000
Martin_Doering at mn.man.de wrote:
> >configure: error: ***
> >    Attempt to build inside of the source tree
> >    Please use a separate build directory, instead
> >Isn't this explicit enough?
> No (maybe I'm a special case ;-) ) - because I thought the c directory
> would be meant by the "source tree". So I startet to go in the subdirs to
> configure it all seperately... There is a directory called build in the
> distribution. So it's not so far away to think, that this is meant.  :-(
Every set of eyes brings a new perspective.  Feel free to make very
explicit comments/suggestions.  Tell me where you looked for the
information
and did not find it.  Even better send patches. :)
> So you see: This all is really new to me - sorry. Yesterday evening I
> browsed through the mailinglist archive and found many things bringing me
> further - especially setting "CC=gcc ./configure ..." and additionally
> there is a patch,
CC=gcc is usually a Cygwin issue.
> if I make all targets the make process fails (as told in
> the archive - some typo...). Maybe it's getting better if I just use one
> target, as I wanted at first.
I have wondered if this behavior needs to be changed. No one can
possibly
really mean to do this. :)
> I will try to write a small basic readme especially covering the problems
> I had, if I'm done. You are right: The documentation is very explicite,
> but I just wanted to know a few things. I'm mostly familiar with building
> software packages.
RTEMS is just another software package.  It is just one that is cross
compiled.  That brings a new level of complexity and hence opportunities
for confusion/mistakes.
> Thanks for your help. I will try it with your commandline.
> Martin Döring, Systemtechnik (IDT)
> MAN Nutzfahrzeuge AG
> Dachauerstraße 667
> D-80995 München
> Tel.:   +49(0)89 / 1580 - 1199
> Fax:   +49(0)89 / 1580 - 91-1199
> E-Mail: Martin_Doering at mn.man.de
