[Fwd: Re: feedback requested on proposed new directive]
Rosimildo da Silva
rdasilva at connecttel.com
Sun Aug 27 16:01:37 UTC 2000
This bounced a few times.... I have seen the echo of it...
Rosimildo.
From: Rosimildo da Silva <rdasilva at connecttel.com>
Subject: Re: feedback requested on proposed new directive
To: joel.sherrill at OARcorp.com
CC: rtems-users at OARcorp.com
Joel Sherrill wrote:
> We are considering adding a new directive to expose functionality
> that has long been in the SuperCore. It is an alternate task
> entry style that follows "main". Your task's argument list would
> look like:
> rtems_task MYTASK( int argc, char ** argv )
Why not a signature to match main():
int MYTASK( int argc, char ** argv );
> The directive would look something like this (naming suggestions
> requested :).
> rtems_status_code rtems_task_start_main_style(
> rtems_id id,
> rtems_task_entry entry_point, /* probably need another type? */
> int argc
> char **argv
I guess the idea is to start main() routine from it ?
Are you planning to remove the call to main() from boot_card.c ?
rtems_status_code rc;
rc = rtems_task_start_main_style( id, main, argc, argv );
What happens when exit() &/or assert() are called ?
I guess it is important to know what we are trying to
archive here:
+ have a stardard way of starting up RTEMS.
+ making easier porting 3rd party applications
+ providing a standard configuration
All programmers expects something similar a "C" program
as an entry point for any application.
A RTEMS newbee would like to have this fisrt application,
link it against RTEMS libraries, and get up and running.
At this moment, he/she should not be worried about
configuration, init task, stack size, prority, etc.
int main( int argc, char**argv )
printf( "Hello World\n" );
return 0;
Rosimildo da Silva rdasilva at connectel.com
ConnectTel, Inc. Austin, TX -- USA
Phone : 512-338-1111 Fax : 512-918-0449
Mobile: 512-632-7579
Company Page: http://www.connecttel.com
Home Page: http://members.xoom.com/rosimildo/
