Bare BSP's `bsp.h'.
Wed Aug 30 13:50:37 UTC 2000
Chris Johns wrote:
> Hi all,
> I have just noticed `CONFIGURE_INTERRUPT_STACK_MEMORY' is now defined in
> the bare BSP's `bsp.h'. It happened on rev 1.2.2.1.
> IMO this should not be defined here and left to the external BSP to
> define.
> Should it be removed ?
Check confdefs.h... I think if it is not defined, then confdefs.h
will default it to minimum stack size.
>  Chris Johns, mailto:cjohns at cybertec.com.au mailto:ccj at acm.org
