[Fwd: Re: feedback requested on proposed new directive]
Wed Aug 30 14:10:23 UTC 2000
Rosimildo da Silva wrote:
> Joel Sherrill wrote:
> > We probably should borrow an idea I worked out for GNAT/RTEMS.  There is
> > an RTEMS init task (API flavor is irrelevant).  It does whatever it
> > takes to initialize things before calling "Ada main".  What about
> > something like this?
> > rtems_task Init()
> >   int status;
> > #if defined(GET_ARGS)
> >   gets(cmdline);
> >   parse cmdline into argc, argv
> > #endif
> > #if defined(MOUNT_REAL_DISKS)
> >   initialize disk based filesystems
> > #endif
> > #if defined(HAS_NETWORKING)
> >   initialize networking
> > #endif
> >   status = main( argc, argv, environp );
> >   exit( status );
> > As time goes on, I can see other initialization that would have to be
> > inserted
> > before main() -- network initialization is already there.  Mounting
> > a real disk filesystem would be another.
> > [I can easily see a way to instantiate this code via something like
> > confdefs.h.]
> This sounds good. As long as the "init_task()" it is located alone
> in a module and let people be able to use its own, if needed.
That was my intent.  I really don't know the best way to work out
the details.  On one hand, you have the default configuration
information
(dummy) and ideally the Init->main task would work the same way.
But I don't see how it can.
> > Given the above scheme it would if USE_INIT_FINI were defined in bsp.h.
> Yes.
OK.  This  makes me lean toward instantiating this function
as part of confdefs.h.
Eric N... how could we integrate a dummy+main and possibly
a loopback network configuration into RTEMS packages?  I know
based on our off-line email that having a network configuration
breaks the select tests.  But you need it to link some of the
tests (in particular MySQL).
> > One of the network demos (ttcp?) has code to convert a string into an
> > argc/argv
> > type arrangement.  Then the "ttcp_main" is invoked with them.  The
> > example above
> > I hacked would call that code.
> It is ok. But, getting the string from "stdin" would be a mistake if it
> is used
> by default. Just my opinion here.
It should not be used by default -- it would be useful in test harnesses
though.  This was my solution to Charles G's problem.
> Rosimildo.
