IP Multicast
Smith, Gene Gene.Smith at sea.siemens.com
Tue Aug 1 21:26:18 UTC 2000
Thanks for the info. Do you think broadcast, as opposed to multicast, works
as is?
It looks to me like it would.
-Gene
> -----Original Message-----
> From: suvrat gupta [mailto:suvrat at utstar.com]
> Sent: Tuesday, August 01, 2000 5:16 PM
> To: Smith, Gene
> Subject: Re: IP Multicast
> I looked at it about two months ago. Seemed like most of the
> IP stack does
> support it..  The ethernet driver needs to support multicast related
> ioctls(add/remove address in the H/W filter).this can be done
> by usingl
> ether_addmulti() ether_delmulti() functions(you may need to
> modify them a bit.
> Try using the latest RTEMS code.
> hope this helps. In case you do come to know of some working
> implementation,
> let me know.
> -suvrat
> "Smith, Gene" wrote:
> > Is IP Multicast actually supported in RTEMS?  If so, has it
> been used by
> > anyone?  All the drivers in "network" directories seem to
> say FIXME and
> > ERROR when referring to multicast.  I didn't see multicast
> mentioned in
> > Networking Suppliment.
> > My application might need some form of multicast.  However,
> a simple subnet
> > broadcast might do.
> > -Gene
