building RTEMS alone
Tue Aug 1 22:07:55 UTC 2000
If the .h files are in INSTALLPOINT/TARGET/include then RTEMS
will automatically see them.
The configure line by hand should be something like this:
.../rtems-XXX/configure --target=lucent16000-rtems \
  --prefix=INSTALLPOINT
I don't know what "target" cpu you are calling the 16000.
I would guess that config.sub has to be modified though.
It sounds like you are getting past the intial configure
steps though. :)
I hope this helps.
--joel
Ahmet Akkas wrote:
> Hi everybody,
> I am working on porting RTEMS to Lucent's 16000 DSP processor by using
> Lucent's tools (compiler, assembler, etc.). I have already build newlib
> library. Right now I want to build RTEMS without using bit_rtems script
> (as you know bit_rtems build gcc and newlib together). I used bare bsp
> option only build the kernel.
> Anyway, my question is the following:
> I will run configure command with its options under the build directory.
> The part I do not know is that even in the configure command, I set --includedir
> variable to the library I want to use it, configure command it copies the
> content of "includedir" to the Makefiles under the build directory but in
> the compilation (it was compiling libc) it still does not include the directory
> I specified in configure command.
> Please let me know if you have any suggestion.
> Thanks in advance.
> Ahmet Akkas
