configuration
gerke.kok at tpa-nl.com
Thu Aug 10 06:51:13 UTC 2000
Hallo,
see the mailing list. There should be something about the LIB and
INCLUDE_DIR environment options that are bugging you. You probably have VC
installed as well.
Also I would not hurt to install automake and autoconfig. And perhaps you
should check the availability of perl in your cygwin instalation...
wkr,
Gerke
> -----Original Message-----
> From: D.G.Somerton [mailto:dgsomerton at hunterwatertech.com.au]
> Sent: Thursday, August 10, 2000 08:29
> To: rtems
> Subject: configuration
> Hello,
> I have attempted to configure the v4.5 beta 3 rtems source.
> This failed.
> I am using cygwin, whose cygwin1.dll file shows v1.1.2, API
> version 0.21,
> Build date 2000-06-06 22:20, Product version 1.1.2, Shared
> Memory Version 3.
> I am using NT 4 SP 6
> I am using the bash shell.
> Here is the tree:
> /tools -> the pre-build executables. = /opt/rtems
> /opt/rtems-4.5.0-beta3a -> the rtems source
> /opt/build -> the build directory
> $cd /opt/build
> $../rtems-4.5.0-beta3a/configure --target=m68k-rtems
> --disable-posix --disab
> le-networking --disable-itron --enable-rtemsbsp=m68k-rtems >z 2>&1
> Here is 'z'
> loading cache ./config.cache
> checking for RTEMS Version... 4.5.0-beta3a
> checking host system type... i386-pc-cygwin32
> checking target system type... m68k-unknown-rtems
> checking build system type... i386-pc-cygwin32
> checking rtems target cpu... m68k
> checking for a BSD compatible install... (cached) /usr/bin/install -c
> checking whether build environment is sane... yes
> checking whether make sets ${MAKE}... (cached) yes
> checking for working aclocal... missing
> checking for working autoconf... missing
> checking for working automake... missing
> checking for working autoheader... missing
> checking for working makeinfo... found
> checking whether to enable maintainer-specific portions of
> Makefiles... no
> checking if the test suites are enabled? ... no
> checking if cpu m68k is supported... yes
> creating ./config.status
> creating Makefile
> creating tools/Makefile
> creating make/Makefile
> creating make/custom/Makefile
> creating make/Templates/Makefile
> creating make/compilers/Makefile
> creating doc/Makefile
> configuring in tools/build
> running /bin/sh
> ../../../rtems-4.5.0-beta3a/tools/build/configure
> --target=m68k-rtems --disa
> ble-posix --disable-networking --disable-itron
> --cache-file=../.././config.cache
> --srcdir=../../../rtems-4.5.0-beta3a/tools
> /build
> loading cache ../.././config.cache
> Makefiles... no
> checking for Cygwin environment... no
> checking for mingw32 environment... no
> checking for executable suffix... configure: error: installation or
> configuration problem: compiler cannot create executables.
> configure: error:
> ../../../rtems-4.5.0-beta3a/tools/build/configure failed
> for tools/build
