OR1K tools
Joel Sherrill
joel.sherrill at OARcorp.com
Sun Aug 13 21:54:58 UTC 2000
Thanks. I will try to put or1k-rtems targets in as soon
as possible. This accounts for the threading support
for the language libraries and other minor issues.
I started putting together the RPM specs Friday afternoon
but did not try to build yet.
Damjan Lampret wrote:
> Hi,
> the following tools are available from opencores.org server:
> - GCC 2.95.2 (or32-gcc) at
> http://www.opencores.org/cores/or1k/or1k-gcc.tar.gz
> - GNU binutils 2.9.1 (or32-as, or32-ld etc...) at
> http://www.opencores.org/cores/or1k/or1k-binutils.tar.gz
> - OR1K simulator 1.9 at http://www.opencores.org/cores/or1k/or1ksim.tar.gz
> All .tar.gz include precompiled binaries for i386/Linux just in case you
> would have troubles compiling this stuff (just do make install in this
> case). Simulator runs from directory where you untarred it (no make
> install for it).
> Let me know if you have problems with downloading it/installing it or
> running it.
> regards,
> Damjan
joel at OARcorp.com On-Line Applications Research
