There's a error in building Cross binutils-2.10 on windows NT 4.0
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Thu Aug 17 12:03:10 UTC 2000
guobing wrote:
> Hi,all!Recently I have been building cross binutils-2.10 on windows Nt 4.0.My components is binutils-2.10,cygwin-1.1.4,My target is i386-rtemself.My configure command is "/source/binutils-2.10/configure --target=i386-rtemself prefix=/usr/local".
--prefix=/usr/local would have been correct.
However, as I tried to explain in another mail recently, using
--prefix=/usr/local is error-prone at best and should be avoided for
cross-toolchains unless you exactly know what you are doing.
The error message look as follows:
> make[3]: Entering directory `/cygdrive/d/temp/unix/build/binutils-2.10/binutils/po'
> make[3]: Nothing to be done for `all'.
> make[3]: Leaving directory `/cygdrive/d/temp/unix/build/binutils-2.10/binutils/po'
> make[3]: Entering directory `/cygdrive/d/temp/unix/build/binutils-2.10/binutils'
> /bin/sh ./libtool --mode=link gcc -g -O2 -W -Wall -o size.exe size.o bucomm.o version.o filemode.o ../bfd/libbfd.la ../libiberty/libiberty.a ./../intl/libintl.a
> gcc -g -O2 -W -Wall -o size.exe size.o bucomm.o version.o filemode.o ../bfd/.libs/libbfd.a ../libiberty/libiberty.a ./../intl/libintl.a
Where does libintl.a come from? binutils-2.10 doesn't have nor use
libintl.a.
> Anyone can help me?Thanks.
Ralf
PS.: Please reconfigure your mailer to correctly insert line-breaks.
All postings originating from you are almost unreadable because
line-breaks are missing :(
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung
(FAW)
Helmholtzstr. 16, 89081 Ulm, Germany Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de FAX: +49/731/501-999
http://www.faw.uni-ulm.de
