stacking of rtems_clock_tick?
Joel Sherrill
joel.sherrill at OARcorp.com
Sat Aug 19 18:00:17 UTC 2000
"Aaron J. Grier" wrote:
> > > sp tests 11, 14, 22, and 24 are all bombing out with
> > > _Thread_Dispatch_disable_level is (0) not 1
> > > any ideas?
> > Which version of RTEMS are you using?
> 4.5.0-beta3a.
The code is OK then... read on...
> > This integrity check was fairly recently added and some tests tried to
> > print from context switch user extensions which ended up violating
> > this.
> > Where is the failure?
> c/src/tests/sptests/sp11/timer.c line #95, in TA2_send_10_to_self()
> c/src/tests/sptests/sp14/task1.c line #31, in Signal_3_to_task_1()
> c/src/tests/sptests/sp22/delay.c line #30, in Delayed_resume()
> c/src/tests/sptests/sp24/resume.c line #32, in Resume_task()
> all failures are generated from the directive_failed_with_level macro,
> and all above functions are being called from _Watchdog_Tickle.
I checked sp11 in particular and the code assumes that the timer
routine is being invoked from clock_tick from an ISR. See below..
> shouldn't _Thread_Dispatch_disable_level be 0 if you're being called
> from a watchdog, since _Watchdog_Tickle_Ticks is separate from
> _Thread_Dispatch?
No... _Thread_Dispatch_disable_level is a critical section counter
and is always >= _ISR_Nest_level. In a clock tick ISR, the count
should be >=1 and so should the _Thread_Dispatch_disable_level.
If the ISR occurs inside an RTEMS critical section, then
_ISR_Nest_level = _Thread_Dispatch_disable_level + 1. If outside
an RTEMS critical section _ISR_Nest_level ==
In this case, I have no idea how the timer is being fired from
an environment where _Thread_Dispatch_disable_level is 0!!!!
This looks to me like the ISR_DIspatching code is not incrementing
_Thread_Dispatch_disable_level for some reason. I recall you
are on a 6830x. Do you have a VBR or are you using the 68000-style
interrupt tricks? Handwalk through the isr vectoring code. The
first instruction in _ISR_Dispatch is this:
addql #1,SYM (_Thread_Dispatch_disable_level) | disable
multitasking
So it should be >= 1 if you are really invoked from an ISR.
Chris Johns... do you have any suggestions? I think he started
with the gen68302 BSP?
> Aaron J. Grier | Frye Electronics, Tigard, OR | aaron at frye.com
> "Cthulhu for President. Why settle for a lesser evil?" -- Matt Minnis
joel at OARcorp.com On-Line Applications Research
