OR1K tools
Fri Aug 25 19:19:25 UTC 2000
Damjan Lampret wrote:
> Rosimildo da Silva wrote:
> > Joel Sherrill wrote:
> > > Thanks.  I will try to put or1k-rtems targets in as soon
> > > as possible.  This accounts for the threading support
> > > for the language libraries and other minor issues.
> > > I started putting together the RPM specs Friday afternoon
> > > but did not try to build yet.
> > I am just visiting my TODO folder. Where are we here ?
> Sources for the latest tools for OR32 are in opencores's CVS. Joel will
> patch them for RTEMS and build RPMs.
> I am currently playing with basic BSP for the OR32 style CPUs. BSP
> library builds fine. Only problem is libc library.
> Also RTEMS library builds fine.
I will add to that I tried to check the tools out today from
opencores.org but the cvspserver complained about the files.
I have made similar mods to older or1k tool versions and will
just merge them into their repository as soon as I can
after checking the source out.
> regards,
> Damjan
