Rtems in Flash and Application in RAM
Fri Dec 1 22:33:49 UTC 2000
Peter Mueller wrote:
> Hello,
> I'm looking for info how to move rtems to Flash memory and application
> code in RAM (because of debugging). I assume this is possible, the question is
> how and how big is the effort.
> I think there are two points:
> - separate application and rtems in different memory areas (segments?)
> - have a stub library for the linker that knows about the rtems
> addresses...
> Any info, experience out there? Papers from GNU covering this?
I believe this is essentially what Chris Johns is doing with
My Right Boot.  It is at http://www.cybertec.com.au/mrboot.htm
I would greatly appreciate anyone who can
make progress in a standard procedure that separates RTEMS
from applications and provides separate loading of applications.
If this can be done in a processor independent manner, that would
be fantastic.
> Peter
> Sent through GMX FreeMail - http://www.gmx.net
