GNAT/RTEMS and ACATS Suite
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Dec 5 22:52:11 UTC 2000
A bit of progress (tiny one) is attached. I have added some
to runall.sh which lets you do this
../runall --> native
../runall TARGET --> use TARGET
It sources a config file in the config directory to get the
definitions of the routines. I think this is sufficient to
do it. :)
I am trying ot run things natively on the 3.13p binary from ACT
as a starting point. I am getting to this point.
gcc -c widechr.adb
impdef.ads:327:59: expect signed integer type in instantiation of "Num"
impdef.ads:327:59: instantiation abandoned
gnatmake: "widechr.adb" compilation error
+ [ 4 -ne 0 ]
+ echo Failed to compile widechr
+ exit 1
Could you take a look and see what is wrong? It looked like some
of the paths were wrong on sed's since I was getting errors.
FYI I also added code to detect that directories such as download
and mod were missing and to create them in that case.
Thanks.
joel at OARcorp.com On-Line Applications Research
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20001205/442970eb/attachment.obj>
